Make a really good Properties Pallete
Properties Palette is almost like a bad joke. Most of the times it lacks essential information like structural column height. "Column is from level 1 to level 2" is just so irrelevant for an engineer! Engineering means numbers, not useless words. Every structural object must be completely described in numbers, each number representing a parameter or a characteristic. Engineering needs no poetry, don't try to describe objects in words, describe them in bare numbers. Like in Autocad.
0
votos
