Show in System Browser
I would like a 'Show in System Browser' button. Oftentimes I'm working in the model and for whatever reason, I need to go find a circuit or model element in the System Browser. One application is when a fixture on the circuit has moved out-of-view due to a hosting problem, and I need to find it to select it and reset its Elevation or something.
I would also like to see this button available in Panel Schedules. Sometimes I see an errant Load Classification in the schedules load summary, so I need to go to the system browser to track down the particular fixture with the error to correct it.
A "Show in System Browser" button would be much faster than trying to navigate the system browser, especially on large projects.
EDIT: To be clear: I want the System Browser to open and expand to the selected element when the button is selected. I know that if the System Browser is open and you select an element then the element will highlight in the browser. However, if the Browser is collapsed, the parent will highlight, then you have to expand it, then go click the model element again, then expand the highlighted parent, and so on. That takes a long time.
