Revit 2019 stair run-thickness.
It would be great if you can specify the running thickness in Revit when creating a staircase. So far always two stairs must be drawn.
Comentarios
Hey Michael, could you illustrate with a picture? I don't really understand what this is about.
I would like to define the statically calculated stair run thickness, but find no adjustment.
In the sectional view, therefore, the staircase is not correct. That's the problem
Not sure I'm understanding the problem.
The run thickness is a type property of the 'run type'.  See more information here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Depending on what type of stair you are creating, you might want to look at 'structural depth' (for example for concrete stairs).
Or are you proposing to have this parameter be an instance parameter?
