Draw Pipes parallel to selected walls or selected lines
As an MEP-Engineer i often find it really time-consuming drawing Pipe-Systems in Rooms with non-orthogonal walls. Often I Need to correct the angles of the Pipes because they are off by 1 or 0.5 Degrees and therefore cant smootly connect to other parts of the pipe-network. A function to controll the angle of the Pipe by selecting which line the pipe should run parallel to (WHILE DRAWING!) would be a great help.
The "Align Elements"- Function does Change the Angle BUT also the Position of the Pipe. At the Moment im using  Detail-Lines to draw after, which is really time consuming and i also dont want to rotate the views all the time.
The Screenshot underneath was taken from a plan view.
Comentarios
I need help too, same problem
It only works in Revit for Walls in the Host Modell, but not for walls in a linked Revit Modell, please change this.
