Nested Detail Components in Mullion Profile
Currently, detail components nested into curtain wall mullion profiles cannot be dimensioned or otherwise snapped to in the project. This need to be fixed soon please. Otherwise there is almost no point in having this ability to nest details into the profiles since it becomes a manual process to verify the dimensions. Not very Revit like. Fix this soon please. It would be greatly appreciated. Thanks.
Comentarios
this needs fixing, the only work around at the moment is to manually insert the detail component and lock it to the geometry on every detail where you need to dimension to parts of the detail. a real PITA when doing window & curtain wall  assembly drawings.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
