Can you pls share the link for the wall cladding and lining material. Thanks heaps
03-13-201904:22 PM
03-13-201904:22 PM
Hi, To unlock the lining layer in section you just need to select the wall type in the model then in properties browser select 'edit type' then under structure select 'edit'. then follow the steps below (screenshots at bottom):
1. Select 'Preview'
2. Change view to section
3. Select 'Modify'
4. Zoom in to wall and select the bottom or top edge you want to unlock
5. Toggle the padlock icon to unlock/lock the layer so you can then use the blue grips in a section view to drag the layer as desired.
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months. Please feel free to re-word (titles and clear descriptions for specific features or enhancements are very important) and resubmit this Idea.
