Curtain wall: Continuous mullions (not splitted at curtain grid lines)
It is possible to make mullions "continuous" or to "break at join". But when I choose continuous, then there are still 2 mullions. It would be nice to have the option to make mullions "real" continuous that we can see the real length of the mullions at the schedule.
Comentarios
The ability to make mullions continuous on both directions without cutting the panels should be added. It is a construction method used everywhere in the whole world.
Each direction with a depth offset from the other, and one continuous panel.
Observer
Observer
It is time to aknowledge that bim-models are no longer good enough as just a resemblence of the construction. With requirements today, modeling should be as close to the real world constructing methods as possible. Workarounds are no longer good enough for deliveries to entreprenours.
Please add the ability to make mullions continuous on both directions.
