Temporary View Properties - Allow phase change
When Temporary View Properties are enabled on a view with a View Template assigned, the user cannot change the View's phase - its still controlled by the Template.
When Temporary View Properties are enabled the user should be able to change the Phase along with all of the other view properties that are enabled.
