Nested Families in Assemblies.
This would be a great addition to the toolset in Revit especially with the amount of detail that is required in the projects nowadays.
Restrictions & Description.
I have families that are built up of nested families (all with the Shared Option ticked). When I place them in a project, I am able to schedule them with no problem at all. All good so far.
I then place create logical assemblies to ease the creation of drawings for fabrication.
Firstly, the families with nested families are not even visible in the created view but the scheduling lists the top-level Family, secondly using the same process but without the share in the nested families and I am able to produce views and drawings but the schedules are of only the top-level Families (as one would expect).
I am at a loss as to why this functionality is not supported.
On investigation I have found that this has been a knows restriction from 2013 – isn’t it about time this was sorted out?
