Custom Scale 'Display Name' value added to Properties / View Templates
Currently the 'display name' override for custom scales is only available when clicking 'custom' from the pull up menu in the bottom left corner.
What that means is this value can only be edited by opening each view individually. Currently even when you create a view template from a view where this has been applied - this value will not be carried over to that view template.
I think this value should be accessible as both a view property (which can then be edited in a schedule) and in view templates. It is already a value so why not make it accessible?
MP
Comentarios
Hello!
I agree!
There are several requests on this forum requesting scaling changes and additions. If it were possible to add scales to the list, it would be a big step forward, as we could apply to other views more quickly by just accessing the list of scales, without having to include them in the view template.
Here in Brazil, we use the 1:75 scale for some types of projects and it is not available in the Revit scale list in Portuguese.
