Fabrication duct in Revit - swap fitting coupling in for short duct section
When there is a short piece of spiral duct between two fittings, I would like to see the option to swap the duct out for a Fitting coupling, & have the 2 fittings remain connected (even if the pipe is slightly longed that the coupling).
