Import Data from Drone into Revit Conceptual Massing Environment
I would like to be able to import drone data such as RCM, OBJ and RCP files directly into the Conceptual Massing Environment to do quick massing studies with real world scan data as context.  Currently, you can only import dwg, dxf, dgn, sat, skp and 3dm files.
Comentarios
Hi @dzanta ,
With Revit 2022.1 you can now import .OBJ file format (but not link it), and is not posible to import it by Shared Coordinates. Only "link" support shared coordinates.
You can not link ReCap formats on Conceptual Mass Family, but you can model a mass-in-place directly on the project. RCM is still no posible to supported in Revit.
