Snap families to architectural families
If you enter a room most light switches and sockets get installed near the opening side of the door.
Could you make the switches snapping to the door? So for example I've got 300 doors, all the same, why can't I position one lightswitch 150mm away from the doors opening and Revit can do this the next 299-times for me? Of course errors would occur and it should be possible to choose one or two exact door types and I'm sure that Dynamo can handle this, but isn't Dynamo for such a relative simple task a little bit of an overkill?
Light switches are just one example, most electrical positions get determined by architectural factors. Thanks for improving Revit! It's for now a good program but there is always room for improvement ![]()
0
votos
