Design Options Idea
Design options are super convenient and allow our busy visual minds to try out our ideas without messing previous work. The only issue I've run into is the unclickable/unnoted part. When you're in the main model, it makes sense not to be able to change anything that lives in the design option but it would help if the all the content would highlight and you would get a corresponding highlight box under your mouse that states the design option you're highlighting. (something similar to a Revit link)
I don't know if its possible but it would definitely eliminate a lot of frustration, I hope this helps! Thank you.
Comentarios
