I should probably note I want this because my home office setup includes a 4K monitor on the left and a 1080p monitor on the right. It's almost impossible to span a single session across both monitors because of the resolution difference between the monitors. To do so, I'm either forced to set the 4K monitor to 1080p resolution, or line the bottom of the window up with the bottom of the 1080p screen. Doing the second leave a bunch of unused real estate at the bottom of the 4K screen.
The way I envisage it so that you don't have every new view/sheet open in a new window floating around would be to either right click to open a view in it's own window or to have an on/off toggle for opening views in seperate windows.
The way I see it, i would like to set the 3D view (maybe two 3D views on the first monitor), and floorplans on my second monitor. This for an overall look of my project to view the effects of changes I made to the project floor plans. But this can work with anyway you want to overview your project. Like elevations on monitor 1 and sections on monitor 2 or whatever you are using.
Swapping the properties box to the second monitor while working on the first monitor is not working well, because you have to swap your mouse to the second screen constantly to adjust something. It's more the way to have a quick look like i mentioned above.
I am not sure this is the spot to write this, but it might help to some extend until the second screen functionality is integrated into Revit.
I heard customers say that Enscape can be used on the second screen for the visualization, similar to what you described. It only gives you the visualization and not the settings but it might be a start.
06-15-201605:20 AM
06-15-201605:20 AM
Missed this one - I sent up a post with a few interface improvements including multi-monitor, apologies for the dual post. Feel free to vote mine up, too, perhaps multiple similar ideas will get more attention?
Thanks for your submission and votes on this idea! We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
08-04-201606:21 PM
08-04-201606:21 PM
I've already suggested this elsewhere but I might as well reiterate here. This is pretty easy to implement. All that needs to happen is Revit must ditch the silly MDI display model in favour of a multiple window one. Once this change is made then any window can be placed on any monitor without any problems.
Bitte auch an die Triple-Monitor-User denken, bislang über 2 Instanzen versucht das Problem zu kompensieren, äusserst lästig, kann doch wirklich nicht die große Sache sein.
But archicad still cannot display dynamically an operation in two views. If you draw eg a wall in a 2d view when you move the mouse you don't see anything in 3d view. You only see when you click the endpoint
It would be much easier to work with two, or more, displays if editing windows could be dragged outside of Revit's parent window.
10-17-201607:22 AM
10-17-201607:22 AM
Add hotkeys for this when you implement it. Something like what windows does would be fine. windows key-right to the right, windows key left to the left, etc.
Just to be clear - are you asking about being able to drag the 3D view window outside of the application window, so that the application window doesn't have to be stretched across the second monitor?
Yes, streching does not work very well, especially when you don't have two identical monitors. The properties window can be moved outside the application. I would like the same for views (3d views, sections floorplans schedules etc.)
It would be great if you could have a live 3D view in a separate pop out window so that it can be moved around independently of the Revit window. I find having the 3D view open in a window tile situation very awkward to use. Currently Revit supports the ability to pop out the properties palette and project browser and this is extremely useful, especially when using Revit on dual monitors.
02-08-201701:58 AM
02-08-201701:58 AM
Excellent idea, a 3d view that works like a pallete. This would certainly free up screen space, especially considering most people in the industry work with a second screen setup. No need to constantly press WT all the time to get back to a 3D View!
Excellent idea and something that definitely needs to be implemented fast. I think that it would be good if views/windows could be controlled in the same way that you can control the project browser and properties pallets in the sense that they can either be snapped into the main Revit window or they can be popped out and moved around your monitors independently of the main Revit window.
Here here! If you could have separate windows like Photoshop, you could use then to snap to full screen or tile them or whatever with the built in windows 7 window tab commands (e.g. windows-up, windows-up, etc.). I'd rather not have Revit reinvent the wheel for window management if possible. Of course any UI improvement in this area would be welcome. All we have now is W-T for tile all windows.
Being able to support different monitor sizes would be great. I'd suggest even going further and redesigning the properties and system browser and other elements so you can put all that on say a 20" 1080p monitor on the bottom right of a 30-40 inch higher resolution display for showing the model.
07-11-201711:46 AM
07-11-201711:46 AM
It would be fantastic if users are able to move viewports (windows) outside of Revit without having to stretch Revit across two-three screens with different resolutions. Also be able to drag details to those windows that are outside of Revit and so on.
The opening post and many of the subsequent comments are very positive. As an interesting precedent, Cinema 4D has had the most impressive interface controls I have ever used.
I think a smart way in which Revit could facilitate multi-screen support, would be to allow Revit to launch additional master windows with or without toolbars allocated. These could then easily be full screen / half screen'd via Windows pane control systems.
Then within each of these master windows being able to dock in tools bars and views just as Revit currently supports these actions would first of all be a brilliant start.
To follow, if some further window tiling tools were available to force tile Revit panes by 2x3, 2x2 etc that would be even better. It might be tricky to manage how Revit would tile say the first 4 or 6 of the open active windows, but if the switch window shortcut was allocated onto each views' title bar next to the min/max/close buttons, this would allow you then to switch in and out views as you require.
08-01-201701:16 PM
08-01-201701:16 PM
This is going to spark an "us vs them" war but what the hell
For the record, if there is a record, I am strongly against any sort of "master window" interface where other windows are restricted to the confines of the master window. This is a very outdated UI that I don't believe is any longer suitable for today's work practices.
I am a vehement proponent of an application being able to open as many windows as the user requires to get their job done and I should be able to place each one of those windows anywhere I please on my multiple screens. Also, the application should provide docking and snapping feature so that windows can be grouped (docked together) and snapped to screen edges. Once I arrange my "workspace" I should be able to save this layout for future sessions.
My previous comment is missing a smiley. Here it is:
To get access to Revit preview, send a request to revit.preview.access@autodesk.com
08-01-201702:04 PM
08-01-201702:04 PM
Nice one. Thanks for that. I feel like I'm at the stage where I'll be able to focus my ideas and comments better if I have access to previews.
cheers, -tomek
08-02-201701:55 AM
08-02-201701:55 AM
Hi Tomek,
Apologies if I inadvertently riled you up there. I'm think I'm much in agreement.
To clarify, I was suggesting that if Revit were able to launch additional master windows, this would allow secondary, tertiary, windows to be made full screen within the windows interface, at whatever resolution those additional screens may be.
Within these panes Autodesk would be able to manage tiling within them, where as if they all float around within the windows interface, this would be an issue with the Windows UI and their window pane management? (apologies for making up the terminology here, I'll try and have a swot up to use the correct language in future!)
08-02-201702:03 AM
08-02-201702:03 AM
It's all good, just having a bit of a joke. Anyway, if you have used recently any of Adobe's Creative Suite products or Sketchup or... (I'm a Mac user mostly so I don't know that many Windows apps) you will know what I'm talking about. The application provides one main window. This is the "canvas" or "main view". Some applications allow you to have multiple views of the same "space". Then you have a number of "tool palettes" that can be organised together into larger groups that can be move at the same time and snapped to the edges of other palettes, windows and the screen itself.
This thread is actually exposing a larger problem with the current UI used in Revit: the UI no longer supports us in our work as our projects are simply too big and complicated. With hundreds of sheets, dozens of views open at the same time the primitive Properties and Project Browsers are simply inadequate.
I've been meaning to prepare some mockups of what I think would work really well but as always times is short. Perhaps next time I'm on sick leave I'll be able to get something done
cheers, -tomek
09-05-201709:10 AM
09-05-201709:10 AM
Cant see how to vote this up but this needs implementing ASAP.
09-05-201709:22 AM
09-05-201709:22 AM
Now its on their roadmap when can we expect it to be instigated?
King AUTODESK will not answer to you, I wait since a year
09-06-201701:00 AM
09-06-201701:00 AM
I want to believe that Autodesk set out the Revit development roadmap based on priorities they get from user feedback but sarcasm is not going to make them work faster. We're all professionals here and as such we understand the pressures of continuing development of a sophisticated and complex system. Demanding that something be done because we want it now won't make it happen. It will happen when it does. Hopefully soon because I need this too
09-06-201704:24 PM
09-06-201704:24 PM
I wasn't being sarcastic, I genuinely want to know if there is a time table for this feature.
09-06-201704:25 PM
09-06-201704:25 PM
@Anonymous, unfortunately due to US accounting regulations we are not able to share delivery timelines.
That said, as I mentioned earlier in this thread, I encourage people to join the Revit Preview project so that you can get a glimpse into what's under development at the Factory under a non-disclosure agreement.
09-22-201711:56 PM
09-22-201711:56 PM
I think the user experience must be similar to Adobe Photoshop, when you can simply drag any toolbars/panels as well as any views to the second/multi monitors and it should feel native.
10-10-201710:55 AM
10-10-201710:55 AM
It is already over 12 years we are asking for multiple screen support. It is time to re-vamp the engine.
10-17-201710:37 AM
10-17-201710:37 AM
What about letting us use multiple monitors I would very much like to be able to have a window of the 3d model open on my secondary screen while working in a plan drawing on my primary screen.
10-17-201711:25 AM
10-17-201711:25 AM
This idea has already been accepted into the future roadmap.
This has been discussed so much already. I appreciate that you may be new to Revit and are only just beginning to contribute to this forum (well done you!) but please next time search the forum before posting and then simply vote on the existing idea. Also feel free to add your own comments. Otherwise we just end up with so many duplicates of the same idea. This is hard to manage and no doubt a little frustrating for the board ops.
10-17-201711:15 PM
10-17-201711:15 PM
Hey sorry I'm new to the forum. I'll do that next time ☺️
10-18-201712:14 AM
10-18-201712:14 AM
All good. Welcome to the forum (even though I probably didn't sound very welcoming at all). I know what it's like to be really enthusiastic and full of ideas and to finally find a place where you can speak to like minded people only to discover that there were literally hundreds of similar requests and ideas even before you joined in. Don't let that discourage you from positing interesting ideas. We're all here to make Revit better.
Yes, but could we please have a parameter that assigns categories to screens -i.e. default screen one, 3D views screen two, schedules etc. screen three.
11-10-201707:21 AM
11-10-201707:21 AM
Dual monitorsetup for Revit should be more flexible.
this improve should be think not only as dual monitors, my specific arrangement at home is for 3 monitors, and once i worked in a studio that use in their meeting rooms 5 screens, sometimes they were use as duplicated screen and sometimes as independent screen, this improvement can apply for for all naviswork versions...
I'm pleased to say that we think we have knocked this idea out by implementing new tabbed views and the ability to drag a few out of the Revit frame and on to any number of monitors in Revit 2019. We are marking this as implemented! If you have other needs requests based on the new functionality, please submit additional Revit ideas so that we can get your feedback.
“The Force will be with you. Always.” — Obi-Wan Kenobi
04-11-201804:51 PM
04-11-201804:51 PM
Genius! As far as I'm concerned 2019 is the most monumental release for designers. Thank you so much for working hard on delivering these features. We can't wait to see what other great features will get implemented next.
So I use three monitors, one is very high res, one is just for 3D, so when I boot up Revit I have to drag the 3D to another screen and then resize. Would it be possible to save this setup on shutdown?
