Scope Boxes - Unable to set because of XYZ
We would like the ability to set a scope box for any view regardless of its current crop region settings.
Currently, a the scope box parameter will be greyed out and un-editable for any of these reasons:
- Crop Region shape has been manually edited
- Crop Region may be Rotated manually. Some people do this instead of applying Project North or True North.
- Crop Region>Edit Crop Region may be manually rotated. (individual lines in Sketch Mode)
- Corp Region>Edit Crop Region may not be an exact rectangle or square
I suggest that the parameter be changed to an editable state and simply warn the user that custom changes made to the crop region will be lost, etc.
