eTransmit Browse For Folder Dialog Missing Win10 Network Locations
While I love the eTransmit tool, there is an issue with the Browse For Folder dialog. See the image below.
Windows 10 makes it easier to add network locations to the Windows Explorer (compared to Win7). I'm talking about the UNC locations that Revit loves to use. We can create network locations under My Computer in Windows 10 using the Add a Network Location button in the Windows Explorer UI. Revit's Open dialog can see these locations. But when you use the Browse folders... button in eTransmit, the network locations are not visible. This may be a hole in the Windows API, but Revit's Open dialog doesn't have the issue (but that dialog is a different one from Browse For Folder).
The image shows 3 network locations added to the This PC node in Windows Explorer. eTransmit's Browse For Dialog show all of the This PC node's items except for those 3 network locations. Please add network locations. I use them for most file operations in Revit/eTransmit.Missing Network Locations
