In addition to Create Similar we should have the ability to copy elements with values of instance parameters that were defined in the Project! I am tired of "re-adjusting" all Elements copied with CS!
Couldn't agree more, but why shouldn't Create Similar just default to the same settings as the selected object anyway rather than having to pointlessly re-adjust depth/height/level every time? Autodesk, just sort this out already...
