If this is an immediate concern for you it is worth knowing that ARUtils has a routine to handle this situation - obviously not as good as having the ability built in to Revit.
Having created rooms on the wrong level the effort required to shift them to the intended level is time consuming. The routine also allows you do delete a level and have rooms (and any level dependent items) moved to a specified level.
