View Back Reference
Back References need some enhancements. Some suggestions:
1. We should be able to edit a back reference as an instance property.
2. We should be able to lock a view reference to prevent it from changing.
3. When creating a view using 'reference other view', there should be an option to turn off back referencing.
4. We should be able to add multiple view references. It would be nice if all possible references could be pulled up and checked or unchecked.
Comentarios
All good suggestions.
I found this suggestion on how to work around it, but it appears to work only some of the time:
http://bimination.blogspot.com/2012/06/revit-tips-referencing-sheet-or-back.html
Thanks.
That's exactly what I ended up doing - going back through and hiding section markers and callouts until the back reference had the correct sheet and detail number. Very time consuming though - I ended up going through well over 100 different views to get all the back references correct.
