Fix internal parameters associated with electrical panels
This idea submission is based on this conversation:
Forum Discussion about panelboard parameters.
The basic problem is that in the real world two panels of identical model could be loaded with different main circuit breakers, equipped with different subfeed lugs. Revit does not allow accurate modelling of this because the main circuit parameter is a type class, not an instance. This in turn leads to all kinds of annoying workflows. The general consensus of the users reporting to this thread is that:
a) the built in behaviour is really annoying
b) fixing this would seem to be fairly simple
