Change host of fittings and accessories without moving z direction
it would be nice to have the possibility to change the host of an object (fittings, accessories, etc.) without moving in z direction, as the pipe or duct...
Comentarios
Marking this as implemented.  The problem articulated in the idea has been resolved as of Revit 2020.  If you modify the Level parameter value of a fitting, the element does not move.. rather, the "Elevation from Level" parameter updates relative to the newly selected level.
El estado se ha cambiado a: Implemented
El estado se ha cambiado a: Gathering Support
