Pipe Thickness direct in pipe Family
please inster the Thickness of Pipes in system Family. I need everytime run Dynamo for a parameter native of Revit, why is not visible in system Family?
Comentarios
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
Hello. I can add @marco.defina suggestion.
Variant 1:
Could Autodesk add an opportunity of changing pipe wall thiсkness into quick menu of pipe drawing because in one project we sometimes have pipes of one family type (pipe's segment) and nominal diameter but with different pipe wall thiсknesses?
and Variant 2:
Could Autodesk add an opportunity to make a choice of pipe wall thicknesses of one nominal diameter in pipe segment?
I hope You accept my suggestions too.
