Remember mode selections for commands from prior Revit sessions: Copy, Mirror..
Remember mode selections for commands like copy>multiple, mirrior>don't copy, print to PDF>combine sheets into 1 PDF, etc... from prior Revit sessions.  In some cases like copy, Revit at least remembers your choice from command to command during the session, but then forgets it the next time you launch the program.  Other commands like mirror, forgets each time the command is run.  This are small things, but they happen every day.
Furthermore, when talking about Print commands, it is soooo irritating that default settings are correct but then change when you change a seperate setting:
  1. I change print range from "Current Window" to "Selected Views/Sheets" - Why would doing this change any other setting?  Yet it does, it changes the File radio button from "Combine multiple ...." to "Create seperate files..."
  2. In the Print Setup dialogue, if you change the zoom setting to a specific scale, it for some reason changes the paper placement setting.  Again, why?
This has been going on for years!!!!  Just stop the nonsense!
