Make Filter command behave like in Autocad
In Revit, you select some elements, then use the Filter to narrow your selection to the desired few elements. But first you have to select a bunch of stuff you don't need.
In Autocad, Etabs and other software you can use Filter directly, no need to select "random" stuff first. This keeps me more focused and directed to the specific task i need to do. Please add this feature to Revit too.
Comentarios
