Fix the way Revit Backs up Files
Revit is wreaking havoc with our cloud server backup system.  The way Revit currently backs up files is as follows:
• I have "Project.rvt" open, made some changes, and click Save.
• Revit renames the file "Project.rvt" to "Project.0001.rvt"
• Revit then performs a Save As of "Project.rvt" with my updates.
• I make more changes in "Project.rvt" and click Save
Revit renames the file "Project.rvt" to "Project.0002.rvt"
• Revit then performs a Save As of "Project.rvt" with my updates, and so on.
What this means is that Revit NEVER performs a simple "Save", but always performs a "Save As", and the files never get overwritten.  Unfortunately for server backup systems that support Version History, Revit files never have a version history available because files are technically never overwritten/updated.
This method of saving backups in Revit wastes server space, and means that our server is cluttered with backup files.  We need the following control over Revit backup settings:
• Global option to turn Revit backup files off, and perform simple "Save" commands (giving backup control to our server backup system)
• Global option to set number of backup files (currently it can only controlled on a project-by-project basis)
• Global option to define where backup files are saved
These settings should be available for both .rvt (Project) and .rfa (Family) files.
Comentarios
This is probably only valid with .rfa files.  To stop the backups simply make your project a workshared file (central file). It will no longer add the .0001 to the end.
