Duct or Pipe Material limitations.
There is a limitation in Revit which does not export duct or Pipe systems material color (in shade mode/solid) or hatch to 2D CAD.
Also Revit doesn't show surface pattern applied in Material properties.
To work around we need to use View filters and this process is view specific which is really not required if we make it simple by give all the instances in Material properties itself.
Sunil Patil
