幕墙系统不能替换成外部自适应嵌板
目前还不能破解的难题就是在项目中创建幕墙系统后不能替换成外部自适应嵌板,只能使用内置系统嵌板,而系统嵌板又不能添加必要参数(如四边形嵌板的四条边长和四个角的度数),好消息是可以手动放置自适应嵌板,噩梦是只能一个个的放,暂不能批量替换,所以能否在新版中优化一下幕墙系统对外部导入的自适应族的支持,或者能够手动批量放置! baidu translate: The problem that can't be cracked is that it can not be replaced by an external adaptive panel after the curtain wall system is created in the project, and the built-in system panel can only be used, and the system panel can not add the necessary parameters (such as the four sides of the quadrangle panels and the degree of four angles), the good news is that the adaptive panel can be manually placed, the nightmare is Can only be placed one by one and can not be replaced for the time being, so can we optimize the support of the adaptive family for the external introduction in the new version, or can put it manually in batch!
0
votos
