Change Order of overlapped views on a sheet
Revit should be able to allow the user Change Order of overlapped views on a sheet with "Send to Back" or "bring to top" options.
These are basic functionalities which are in most of the design softwares and it is almost unbelievable that revit doesn't.
Comentarios
I'd like the ability to adjust the draw order of viewports placed on a sheet. In some instances we will "stack" viewports on a sheet in order to get a look for a specific plan. The order in which the views are placed on the sheet effects how they are printed. Rather than removing the views and then placing them on the sheet in the proper printing order, I'd like to just be able to select one and move it to the back, etc.
usefull Guiño
Views on a sheet should be just like detail items on a view as far as stacking order goes. You should be able to control which views are in front of others.
super necessary!!!
Yes, we very often need to overlap views for various reasons, usually as a workaround for other limitations within Revit. You have to be careful how you place the views on the sheet. If you place them out of order, you must delete and start over. Applying draw-order to views would be really helpful.
Has this been fixed ?
As long as I know, they didn't.
There's a plugin called pyRevit that will allow you to do this
Has this been sorted yet Autodesk?  This is pretty fundamental.
I've always wanted this feature. The constant removal/addition of views to get the right look is frustrating, especially when when the models are complex which slows things down trememdously.
Did anyone try this: http://de0qmbqba3hfm.cloudfront.net/attachments/44545/1 ? Seems logical, but i still prefer some explicit buttons or options for this.
@ipseluteWhere did you find the link to that file? Good try... but doesn't work (for draw order).
Dragging the view from the Sheets section of the Project Browser IS a good tip to re-place a view on a sheet, but it's only that: RE-placing the view. It saves you from having to remove the view from the Sheet and hunt it down in the Project Browser so you can add it back again, so thanks for that! But you have to manually reposition it (not a BIG issue if you can snap to another view) AND the View Title (position and line length).
@AnonymousYes, pyRevit > [Drawing Set] > Sheets > Reorder Selected Viewport can help. It's better than the above because it positions the view for you, but it's only a partial solution because it can't re-position the view title due to an API limitation - vote for Open up View title in Revit API to fix that.
@lionel.kai: I just googled it. Strange though, it works for me in Revit 2020 like this: place view #1 on sheet by dragging it from the Project browser, drag view #2 from the Project browser on top of view #1 on the same sheet. You have to actually DROP view #2 on top of view #1. Revit will align the views automatically if they overlap close enough.
This does not work if you drop view #2 outside of view #1. If you place views next to each other, then try to move to overlap them, the view order will not change.
I found no button / option to manually change the view order.
Please autodesk people !! make a button for this! it would be useful for
the user
Also in need of this ability this morning.
very sad it is still unresloved
Observer
Observer
Yes please, we need that button! (Very urgent)
Community Visitor
Community Visitor
Typical of autodesk to charge lots of money for useless RAM hogging software...while ignoring a legitimate request for a usefull function which exists on other software platforms, including THEIRS (autocad).
2018-2022 and counting.
Observer
Observer
I don't know whether the problem exists for upper versions, but while I was working on 2019 version, I was encountered with the same problem. I resolved the issue simply by removing two problematic views, and then dragged them based on their superimposition order, and luckily it worked.
Another vote for this function, please!!
When you have two or more views on the same sheet, it would be nice to select which view to be in front and back. Maybe a "move to front/back" button or similar, or perhaps a layer option?
still a problem. please add this function!
Community Visitor
Community Visitor
Yes, please add this function. It would be very helpful if the user could arrange the layering of viewports; 'send to back', 'bring to front', etc.
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
it is much appreciated!!
5 years later ! We did it :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
This question has been running since 2017. I'm now working with version 2023. Is this solved yet? If it is....it's not easy to find. Makes you wonder what you pay for doesn't it?
Not solved yet... in R24 or R25 I believe.   Can anybody vouch for this?
It's not done in 24 that I can find.
What was done for sort order (for 24 & 25) was in "drafting views" select an object & you'll get an option to send to front/back.
All but useless for anything outside of that environment.
What they have not done is address the original topics request (even though the idea/request was accepted to be implemented).
Original Post was to allow views on a sheet to be sent to front/back.
eg: an overlay of a ceiling layout view placed over a floor plan needs to be selected to move forward/back to get the right visual affect (or better yet, in this example allow a ceiling grid to be viewable in a floor plan in the first place).
@Trev_Smith The feature has been added to the roadmap, but not yet implemented. We'll probably get an update message once it's implemented.
Only workaround now is to place the worksheets on order of appearance (first being below). Once placed, the draw order is fixed. Removing a view from the sheet completely and placing it again will update the draw order and make it draw on top.
I didn't see an option to follow this thread, so adding a comment so I can see the update if/when this actually gets implemented.
