Disable Cutbacks
I understand where the cutbacks come in and the reason why it is beneficial.
It is also possible to manually adjust cutbacks for both selected members, or families.
However, as far as i could find out, it is not possible to globally disable cutbacks for all structural members.
In some instances it would be very beneficial to be able and disable cutbacks, meaning the length of the structural member would match the analytical length. then, if needed and using the join tools available, beams could still be notched or cutback as needed.
This way users have the option for both scenarios.
