To select/change to which element a framing is connected
Currently I have many problems when modeling several beams joined to the same point, to walls or columns. This is because Revit automatically joins a framing to what Revit chooses.
If I have a beam on top of a column, and then a secondary beam shear connected to the first one, Revit join that secondary beam to the column below, not the main beam. I cannot use, for example, Change Reference, because the column is the only eligible faces.
When joining two beams and for horizontal bracings happens something similar, cutting back beams to the face of and skewed bracing and I cannot change to what my structure is connected.
To add the ability to select to which element to connect, no matter the default setup, to be able to change it when needed.
