Customize Face Parameter in All Rebar Tags
"The information you can set in Reinforcement Settings for Path Reinforcement (naming of the Slab Top / Bottom etc.) is only used by the Summary parameter of the Path Reinforcement Tag."
We need this naming convention in other reinforcement tags too. "Top" and "Bottom" won't work for our documentation, and as seen in this thread, it can't be customized (except for within the Summary parameter, which is not flexible enough for our work).
