Change the default cursor behavior from MOVE to SELECT
In Revit, the cursor's default function is set to MOVE an object upon contact - and that is not the best option, and I think it should be changed, or at least left to the user's own choice. Dragging objects in an inaccurate manner is not a good idea anyway, so why is it the default? It really makes you nervous.
Comentarios
You can turn it off here...
You know this doesn't work. Right?
It works for me... maybe you should uninstall and reinstall your revit.
"Dragging objects in an inaccurate manner" drives me crazy. Architects are doing it ALL the time. Then they export it to Autocad. Then all the dimensions goes crazy, all inacurrate, not rounded to integer values. So what, just set the dimension style to round the values, you say. It's not that simple. All the formworks, all the reinforcement, all the MEP paths will go "crazy", all of them having odd values, not identical when it should be identical, complicating the model and all the drawings for no feasible reason. Manually checking all the odd values is time consuming  and mentally exhausting. Again, for NO feasible reason. Please, add more precison to Revit editing commands.
