Display / highlight texts with “Find/Replace” in a View
We often need to change individual texts (Text Notes) at a later time, of which there are several with the same content scattered on the floor plan. Until now they had to be searched manually.
It would be an enormous work and time saving, if there would be a search function, which indicates the location of all texts with the searched content or “jumps” the screen to the position. For schedules, there is a similar feature ("Highlight in Model") to display families in the model.
For text you could add to "Find / Replace" the possibility to show or highlight the found text. Such a function already exists e.g. in AutoCAD (where it´s called "Zoom to Highlighted Result")
