Assign Disciplines with user defined colour schemes to Revit links.
To aid visual coordination checking and element ownership identification we use VG to override the display settings of other consultants models:
E.g. Structural Tekla model is shared as IFC, we set VG for this to display all model elements as light red solid hatch, thick bright red cut lines, and red hatch cut pattern.
This way it is very clear where clashes are and on a sheet that those elements are not ours.
To be able to predefined this within out template would create great consistency and efficiency.
Currently using VG this has to be manually done each time a link is loaded or relinked.
This could be defined as a VG overiding colour scheme in advance, and we suggest, a scheme assigned to a discipline. In that way only the discipline need be assigned to the linked file.
