Select preferred view reference for view title
We need an option to select preferred reference view for sections, elevations & callouts so the view title refers to the desired sheet. A matter of prioritising the referring views.
Eg.
An elevation is created on a plan and placed on a sheet. The elevation marker is visible in multiple plans however the view title may not refer to the desired view.
If we hide the elevation marker in all other views the reference will update to our preferred view. However, we often need to hide the marker in multiple views to get to the correct reference.
It would be much easier if we could right click to find referring views then... select the preferred reference view from the list.
We need a way to prioritise one referring view over another. The time spent updating references can is quite painful when you are working to a deadline.
Lets make revit user friendly!
Comentarios
Many businesses have graphical standards that require a section title to list all plan views that show the section (or elevation).  It would be helpful if there was a choice to match existing standards.
