Parametric Overhaul to Labels
Currently a label can return an ASCII result, but parameters cannot be attached beyond what is in the label.
This includes:
-Vertical Alignment parameter
-Horizontal Alignment parameter
-Ability to be constrained by a dimension, like on a sheet. Constraining should include horizontal center, right, and left, vertical center, right, and left.
-SHARED PARAMETER in GENERIC ANNOTATION (Is there a  reason why this isn't implmented?)
-Font Choice, Size, and all text options (this could be defined in a type, which could at least be accessed via a parent family. Currently one cannot access the ability to LABEL a label by it's type.)
Perhaps LABELS should be their own ANNOTATION FAMILY, which can be NESTED in ANY FAMILY WHATSOEVER. Currently it is a dependent, obfuscated system, and there is a lack of publication material about what it can or cannot do as it varies across different family category environments.
Comentarios
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
