Autodesk Point Layout filter export option
Hi.  I would like to submit the idea for Autodesk Point Layout to have the ability to filter the points so that you can select those points, then enter another filter for other points and be able to add the new points to the ones that were previously selected to export in a single export.  Currently, if you filter a point that starts with PN, you're limited to only selecting the PN points (Power Normal).  If I have PE points (Power Emergency), I would like the ability to add it to the PN points as well.  Because I can only use the filter to isolate the first 2 character of the points only, prior to export, I have to create multiple export files for only a few points.  I do have the option to manually select the points, but it would save a lot of time to be able to add another filter and continue adding the points that have different point name.  Thank you.
