Select element(s) and its hosted elements
I want a new selection mode, locate at the right bottom corner of Revit window. Beside "Select Elements by face". This new mode will allow user select element(s) and its hosted element(s)
For example:
Case 1: I select a wall then this wall and all windows, doors, switch (face based generic model) that hosted on the wall will be selected.
Case 2: I select several beams. Then these beams and all their hosted rebars will be selected.
