Built in PDF Printer
Please give us a built-in REVIT PDF printer instead of having to download from an outside source.
Comentarios
Why can't you just adopt the dwg to pdf driver from autocad?
There have been several Ideas posted about this.
It's currently listed as "Planned" on the Revit Road Map:
http://blogs.autodesk.com/revit/2018/04/13/revit-roadmap-update-april-2018/
Ok that's good to hear. Thanks.
Yeah, I'm gonna keep voting on any idea that mentions this. I think that a built-in PDF generator should be a lot more powerful than external tools as it will have the ability and access to Revit's internals therefore allowing it to generate potentially better output as well as provide better functionality wrt document management.
El estado se ha cambiado a: Accepted
We are pleased to say that we have accepted this idea and added it to our public roadmap - https://blogs.autodesk.com/revit/2020/04/20/revit-public-roadmap-update-april-2020/
Thanks!
-The Factory
El estado se ha cambiado a: Implemented
We are pleased to say that this has been implemented in Revit 2022.
-The Factory
El estado se ha cambiado a: Gathering Support
