"Pre-filter" selection
The Filter tool is one of my favorite thing in Revit.
But, many times when I try to select something, I have to put a big box around everything and then wait a minute or two for everything in the model to get highlighted. Only then can I pick the Filter tool.
I'd like to see a tool where you could FIRST select the categories you want to pick, and THEN create the box.
That could often make selecting considerably faster.
Comentarios
You mean Select a single item from the categories you want, Temporary Isolate category in view, then box select isn't an easy workflow?? (jk)
Great idea.
The current situation is that I can select by crossing all elements in a view and then use the funnel to modify the selected categories. Now there are a lot of ideas to broaden this filter to not _only_ use categories. What I would like to add is a way to set the filter beforehand. I.e. say I just want to select all doors and windows in the current view. I click the funnel, put a check at Doors and Windows and then I drag a selection crossing over the view, selecting only Doors and Windows. Gives less clutter and probably works a lot faster.
I posted the same Idea about (wow) a year and a half ago:
https://forums.autodesk.com/t5/revit-ideas/quot-pre-filter-quot-selection/idi-p/6501077
Good ideas, this will save time well.
If you cannot wait for AD to implement this, pyRevit already has that: It is called Pick.
