Display print setups on sheets
In a similar way to AutoCAD sheet sets, why we don’t have the same option in Revit?
Idea: I want to have an option to display Revit sheets the same way the print setups are (i.e. Black lines)
Summary: Our template is based on displaying model elements/annotations in views/sheets with matching colors to AutoCAD layers to make it familiar when switching between the two programs. These colors make it confusing when linking marked up DWF back to Revit and definitely redlines will be viewed better if the background sheet is set to Black lines by one single click like in the other program.
0
votos
