When moving or copying an element it would be nice to have the ability to select through all the temporary dimensions available.
The image below is just one example of many where you are in a command like move, copy and array where the temporary dimensions show up. I would like to be able to select the angle command and type in the angle and/or then select the distance and change it. This would allow the element to go at that angle and the specified distance.
I often have angles that don't follow the 30, 45, 60 and so on. Adjusting the mouse and trying to get the correct angle is hard and drawing construction lines or reference lines adds time to already tight schedules. If the dimensions are shown lets have the ability to select and change them.
