Edit wall join by moving location point manuall
Improve Wall Joins changing: Allow user change the wall join by drag location point of wall, instead of click on command Wall Joins. By dragging the location point of a wall to any edge of a wall join, for example: join of 3 walls, the geometry of that wall will be priority than 02 other walls. This function may ONLY CAN work for "rectangle" join.
0
votos
