Appending RCP & Revit files into Navisworks
I would like to see an option within Navisworks that would allow for Point Clouds (.rcp) to be included when appending a Revit file into Navisworks. Similar to the "include linked files" check box. We sometimes have point clouds that aren't on the coordinate system that we want to use for documenting the project in Revit (i.e. Finished Floor EL. or Northing & Easting coordinates). This means when the point cloud is brought into Revit it may have to be moved or rotated. When doing this, it creates issues with alignment when the RCP & Revit files are separately appended into Navisworks. With all this said, the append linked files would need to bring the coordinates that the files have in Revit into Navisworks. I just want my files to align easily. We have clients that want Navisworks files of the design in the context of the point cloud. They don't always tells us this until after we are done, so this feature could really help us out. The other option would be if the point cloud (.rcp) file recorded or remembered it's transform values from where it was originally inserted.
