Workflow Memento to Revit software.
Currentely, it is imposible to import meshes from Memnto to Revit.
Why to import meshes int Revit ? See three raisons below :
1- when you will try to make a rendering on points cloud ==> the points cloud disappears,
2- you can't have shadow on on points cloud,
3- in perspective view, you can see through  points cloud,
Full explanation :
http://forums.autodesk.com/t5/memento-general-discussion/workflow-memento-to-revit-software/m-p/6295...
An idea : could be possible to implement  import FBX format capability for Revit  for instance !
Olivier
Comentarios
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
