CUSTOMIZE LINKED VIEWS OF SELECTED LINK INSTANCES, ALL IN ONE VIEW
The ability to customize views of different instance of the same linked file i.e if instance 1 of link A and instance 2 of link A are in the same view, then it'd be able to customize instance 1 to show a different linked view from instance 2 but in the same view
Comentarios
@timonwanga, as far as I know, is posible to override each individual instance of a Revit Link, see the image below. In Revit Links tab of Visibility/Graphic Overrides, you only need to expand the tree of links models and override the Display Settings as you desire.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-Collaborate/files/GUID-EB571589-C335-4525-A8BE-CF1A2493B2F5-htm.htmlhttps://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-Collaborate/files/GUID-EB571589-C335-4525-A8BE-CF1A2493B2F5-htm.html
AKN ha escrito:
Display Settings: Options to override additional settings for each linked model in the current host view. The button displays the current display setting state (By Host View, By Linked View, or Custom).
See Using View Filters for Linked Models.
I found this on Youtube:
This is really helpful, thanks
