Duplicate Username warning
We are a small young company and have been plagued by 'can not reconcile' errors. If there was a built-in warning that two people were modelling with the same username, it would have alleviated about a year's worth of headaches and long hours on the phone with tech support. We luckily ran across a comment on a forum that solve the problem for us.
Comentarios
Observer
Observer
I realize this is an old post, but I am interested in knowing what solved your problem? We are also a small company and have run into problems recently because we share a user name. Is it because of the license we purchased?  I don’t see a workaround with worksets.  We’ve not had a problem before because we were working at different times or different areas of the building, but on a new project we are having frequent errors.
@smaloneyP7HJQ we've also been noticing an increase in Vault issues recently after adding 2 users to our Vault that share a first and last name (Sr. and Jr.).  We've been running into a lot of file resolution errors, version missing or linked to previous version, file version changing while working on assembly, etc.  Are these issues similar to what you have seen?
