Revit 2019 Uncropped Perspective - holding middle mouse button with shift toggle
The 2019 uncropped perspective feature IS FINALLY HERE!! However, it would be very useful to toggle from pan to orbit mode, by pressing the shift key without having to release the middle mouse button.
For example, if the middle mouse button is pressed, the 3d view can be panned. While pressing the shift key (and not releasing the middle mouse button) the orbit symbol shows up, but you cannot orbit the model. To orbit, you have to release the middle button, then hold the shift key before middle mouse click and then you can orbit. The vice-versa is true for switching from orbit mode to pan mode. You would have to release the middle mouse button before you can pan.
Essentially, it would be very useful allowing users to hold the middle mouse button and use the shift key to toggle between pan mode and orbit mode. This behavior has been implemented in orthographic 3d views. It would be beneficial to have the same behavior in uncropped perspective views.
Comentarios
@Anonymous Another idea that would strengthen the uncropped perspective is this one: https://forums.autodesk.com/t5/revit-ideas/3d-orbit-around-the-mouse-by-default/idi-p/7856630
Most of Autodesk programs have this orbit behavior already (recap, formit,...) as well as other common platforms (sketchup, rhino). It allows for more intuitive navigation even in close quarters (inside small rooms etc).
Consider adding your vote if you think it would be beneficial.
@pieter1
definitely agree! voted for that idea a month ago!
We believe this was fixed in 2019.1. If you can confirm this we can close this as implemented. If you don't think your issue is resolved please post again with step by step or maybe you can get us a video.
Steve
seems to be fixed here!
YES!! This item is now fixed in 2019.1. Thank you very much.
The zoom on cursor position was also implemented in 2019.1 which is another feature that ties very well with this one.
Great Work!!
El estado se ha cambiado a: Implemented
Thanks all for confirming - yes, we did address this in 2019.1.  Enjoy!
El estado se ha cambiado a: Gathering Support
