Stack Plumbing Fixtures - Connectors
So this is the issue, the FU counting feature in Revit ROCKS and it's a huge time saver. It would be even greater if I could connect stack fixtures in a stacked connection. I consulted with our plumbing engineers (we are a MEP Firm) and we do connect stacks vertically. Attached is a Revit model with one of our stack families where you can see the fixture units adding up nicely and the vent units doing so too, as long as the stack fixtures are not connected as a stack. Once I conect the sanitary pipe directly down it just carries the FU of the last element, it would be great if these would add up too. Time saver and avoid human error.
Thank you for your time
Sandra Wohlgemuth
BIM Manager @ MKK Engineering
Comentarios
This isn't adding the fixture units in a stacked system because of the connector settings; the fixture units leaving the carrier is specified as 8, so it will always be 8.  If you change the carrier to a fitting the fixture units will flow through, but you have to connect a separate family for the water closets.  You will then get the fixture units calculating as you wish, but will have to adjust for the venting.
